#235623 - 29/09/2004 14:50 jEmplode and "Checking Media"
woops
Does anyone know how to turn off "Checking Media" in jEmplode (i'm using ver 69 now). It does a "Checking Media" before jEmplode starts up and also after i hit the synch button.
The new jEmplodes are fantastic for creating playlists on the fly. Finally, mschrag has given the empeg community what should have been all along.
#235624 - 29/09/2004 15:10 Re: jEmplode and "Checking Media" [Re: woops]
mschrag
Loc: Richmond, VA
It should be a non-forced check media, which should basically give the Empeg the option of saying "nevermind." Are you saying it's doing a full fsck both before AND after your sync?
#235625 - 29/09/2004 16:08 Re: jEmplode and "Checking Media" [Re: woops]
This is not a Jemplode option, it's something that happens on the player side. You use Hijack to disable it. More information here.
#235626 - 29/09/2004 22:47 Re: jEmplode and "Checking Media" [Re: mschrag]
woops
I did some checking and found the culprit to be an incorrect jumper size creating all the problems.(thanks lopan for the parts list)
MSCHRAG: jEmplode is a wonderful product!
TONY: Thanks for the quick answers you give and the wonderful, comprehensive FAQ you have put together.
Thomas
#235627 - 29/09/2004 22:52 Re: jEmplode and "Checking Media" [Re: woops]
Welcome.
#235628 - 29/09/2004 23:31 Re: jEmplode and "Checking Media" [Re: woops]
mschrag
Loc: Richmond, VA
Thanks -- glad you tracked down the problem ...
#314685 - 05/10/2008 12:30 Re: jEmplode and "Checking Media" [Re: tfabris]
Daria
</font><blockquote><font class="small">Quote:</font>
</blockquote><font class="post">
Even disabled in hijack, jemplode is happily trying to check media. And telnetted into the player I see it unmounts the first drive, and then fsck doesn't start.
Sadly, the device is clean, I fscked it by hand when I swapped the drives into my spare player a bit ago.
